Dual TBI
Old Jun 30, 2006 | 02:16 PM
DanS's Avatar
Dual TBI
I just found out about the new set up from DynamicEFI.
Anybody tried it yet? It seems like it could be a dream come true!
Old Jun 30, 2006 | 02:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Sweet. RBob is the man. I will probably be giving this a try, with a 4bbl unit, and a couple of superchargers, and see what happens. I just need more money, and more time. LOL
Old Jun 30, 2006 | 04:13 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Hummm.... I posted something on dual TBI that was rated at 575 fwhp (eclipsing the 400 fwhp mark) but apparently it's been deleted.
OK, here it is again, Bullockmarine's Mercury Marine sterndrive engine:
Mercury mercruiser marine engine accessories Bruce Bullock Marine, skater, fountain, eliminator, performance boat, boating, cigarette, welcraft, scarab
then click on HP575 SCi - 575 HP
MM no longer sells it (Gen 1 engine with dual TBI, blower, atop a 502) but the above is the cached page showing the same detail. I've posted this info before on TGO (do a search)....... but I needed to repost given the recent (now locked) posts. FYI.
Old Jun 30, 2006 | 05:16 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Yah, I talked to RBob about this a while back. Lots of features and is definatly what I'm going to be using on my Crossfire Injection...after the mods and getting everything back together
Old Jul 1, 2006 | 02:17 AM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
If this is 'common' knowledge, please forgive my ignorance. But, where do you get a throttle body with four injectors? I had no idea that anyone made such a thing. Why isn't everybody using them?
Also, how would you run (2) two-barrel throttle bodies? Maybe, using a dual-carb intake manifold? How would you set up the linkage?
One final question. I am running (L31) Vortec heads. I don't ever recall seeing a dual-carb manifold that works with the Vortecs. Does someone make them?
Please explain these ideas further.
Thank You!
Old Jul 1, 2006 | 02:23 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Thank You!
Holley has made a 4bbl TBI for years.
Old Jul 1, 2006 | 08:39 AM
kdrolt's Avatar
Engine: LO3, LO5
https://www.thirdgen.org/forums/tbi/...t=cfm+TBI+dyno
They made approx 390 fwhp using the Holley 4v TBI unit in a comparo test against a PFI setup and a Stealthram. They probably handicapped the TBI test by using the smaller throttle body (700 cfm) than the ones used on the other two engine tests.
Old Jul 1, 2006 | 09:20 AM
Car: 1990 Formula
Engine: 383 Stroker
OK. Well I found a 4-bbl Commander 950 system on the website. But, it is a system with its own computer. Do you need the Holley computer plus the new EBL computer? Or does the new EBL computer replace the Holley computer?
Again, why isn't this the 'automatic' upgrade to every TBI owner (kind of like an open elememt filter)?
Old Jul 1, 2006 | 10:19 AM
kdrolt's Avatar
Engine: LO3, LO5
It's not an 'automatic' upgrade because of the cost. Air filter mods are easy/cheap, so nearly everyone does one.
The Holley system is also more of a plug-n-play upgrade, rather than a cheaper DIY mod. Serious money spent on an upgraded TBI could also be spent on a newer car (LT1, LS1 etc).....
Old Jul 1, 2006 | 10:23 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You can get the TBI by itself.
The 2-bbl TBI isn't even a restriction until around 320 FWHP.
Old Jul 1, 2006 | 11:37 AM
Car: 1990 Formula
Engine: 383 Stroker
Please bear with me. I am very interested in the possibilty of going to this 4-bbl unit. Can someone tell me exactly what is involved in making this change? I understand that I will need the 4-bbl unit, a new intake, and of course the EBL computer. Exactly what else is involved? Are the fuel lines the same? What about throttle linkage? Is the process 'bolt-on' or is highly custom? I saw that the Holley kit (the one that includes the computer) came with a lot of accessories like a new wiring harness. If you just get the TBI unit what else do you need to get to make it work?
Old Jul 1, 2006 | 11:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Holley 4bbl TBI unit hasn't been used much as no OEM ECM could properly drive the 4 injectors. It could be used with the Cmdr 950 but that drove the cost up even further.
With the EBL and the 4 injector modificaiton it is now possible to use either the Holley 4bbl TBI unit. Or use two 2bbl GM TBI units on a dual quad manifold.
I haven't looked for any dual quad manifolds for the Vortec heads. So I don't know if any are available.
If you shop for a used Holley unit (2 or 4 bbl) avoid those units that have the black plastic round caps over the injectors. The good units have the newer style injectors with connectors that protrude horizontally from the injector.
RBob.
Old Jul 1, 2006 | 12:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The TBI unit has 1/4" NPT openings for the fuel in/out. I believe it comes with barbed fittings for these connections. Can also use a 1/4" NPT to -6 AN adaptor and use AN lines. They are not in the exact same location as the stock stuff, so some changes will be required.
The IAC uses the flat 4 connector (instead of the square 4 connector). So you may need to either get an adpator or cut and splice in the flat 4 connector (used on BBC TBI units).
The TPS uses the flat 3 connector same as stock.
For connecting the injectors I don't know if they have an adpator harness or not. The connectors are different then the stock stuff. Or maybe the TBI unit comes with connectors on pigtails. Either way just need to splice the connectors into the existing harness.
I am not sure about the throttle linkage. The one I have has been modified, so I'm not sure of what is stock. I would imagine that it would be similar to what Holley does with their 4bbl carb's. I would place the installation between a bolt on and custom. Some changes will be required, but nothing that requires a machine shop.
RBob.
Old Jul 1, 2006 | 12:27 PM
Car: 1990 Formula
Engine: 383 Stroker
RBob ........... Awesome. Thank you. I have been looking at the Holley website further. The kit comes with an external-tank fuel pump, Oxygen sensor, MAP sensor, and Coolant Temperature sensor. Are these needed? BTW, I already have the in-tank 255l/hr fuel pump. The instructions for the system also state that the transmission will have to be changed from an electronic lock-up to a mechanical lock-up. What is this about? If you splice the connectors for the injectors into the stock connector (or use an adapter if available) doesn't that mean that all of the injectors will fire at the same time? It looks like the 'Commander' system fires them progressively (kind of like the secondaries on a carb). Again, please forgive me if I am asking what some people might think as being stupid questions. Thanks again.
Old Jul 1, 2006 | 12:50 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Your making it a bit too complicated for yourself. The EBL with the injector driver upgrade is an add on to your oem computer, with that you can just bolt on the 4-barrel unit and wire up the extra injectors. You won't be using anything from the holley kit other than the TB itself.
Old Jul 1, 2006 | 05:18 PM
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
I love the idea, because I am debating about building a nice little 355 next year or so. What Id like to know is, can you use the 4bbl, on a 2 bbl, till your ready to step up to a 4bbl? I am trying to get the EBL by spring of next year, and start tuning. And if Im going to build another engine, it is gonna be above 400 hp, which is out of the range of my TB. I just need to practice tuning, on my L03, till Im ready to install the 355. Can I use the 4 injector EBL, with a 2 injector TB, till I get ready to step up?
Old Jul 2, 2006 | 11:19 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Edelbrock P/N 5426 or 7526 (Air-Gap)
Summit has them listed for Vortec heads.
Old Jul 2, 2006 | 12:11 PM
Car: 1990 Formula
Engine: 383 Stroker
BMmonteSS ....... Thank You! Along with RBob, you guys always provide me with the answers that I need.
I don't think the #5426 will work because of the style of plenum opening. I can't find a picture of the #7526. But since they are both #**26 models, I will assume that they are the same. I think #75** just designates the 'Air-Gap' series. Besides that, I believe that the Holley 4-bbl unit is the better alternative and it only requires a standard, single-carb intake. Thanks for the input, though.
Old Jul 3, 2006 | 11:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, it will work. Although it is not the ideal situation. The injectors will have twice the current flow during open time.
. . .doesn't that mean that all of the injectors will fire at the same time?
The injectors will fire in pairs. The wiring is such that 2 injectors are wired in parallel to one driver, with the other 2 injectors wired in parallel to the other driver. Each pair then firing alternately.
RBob.
{edited for spelling}
Old Jul 3, 2006 | 04:09 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Yes, RBob and his buds have made the dream in my previous "Dual TBI" posts a reality. With the EBL, I imagine, you could build a mild 305/350 and run two stock/near stock TBIs complete with an old 2X4 air cleaner for a sweet old school look. Hell, with the EBL and two Ultimate TBIs you could service a big-inch motor, too! Very nice.
Old Jul 6, 2006 | 09:16 AM
DanS's Avatar
This is all great news.
RBob, I've got a few questions for you.
I've heard that it's nearly impossible to tune for a large cam using the stock ecm. Does the EBL system solve this?
Can you give us the details of your engine? Or anyone else that is running your 4 injector set-up? (I'm curious to see actual results.)
Old Jul 6, 2006 | 11:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I should probably first ask what is a large cam. I'm running a 327 with an Isky cam: 224° @ .050, .465 lift, 108 LDA. Fair amount of overlap. Runs like a dream, no, I wasn't able to get decent results with the stock ECM code.
Runs great with the EBL setup. Which is an offspring of code development & tuning for the 327.
I know of others that are running larger cams & the EBL with success.
RBob.
Old Jul 6, 2006 | 11:37 AM
DanS's Avatar
Do you have dyno and/or track #'s for your set-up? What size injectors are you running?
Old Jul 6, 2006 | 07:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I've been trying to get to a track this year. Just way too much rain. This car wasn't built as a track car, but I'm willing to give it a go. Once I do I'll post the results.
As for injector/TBI setup. It currently has the 2bbl TBI on it. Punched out to 2-1/16" bores, with 81 #/hr injectors at 22 psi. At that pressure they are flowing 112 #/hr each (using 11.5 psi as the 81 #/hr rate).
I recently went back to using the vacuum adjustable fuel pressure regulator (VAFPR). This works out great. In testing the EBL code I keep switching from one setup to another. Once back to the VAFPR I was happy with the results. It makes a world of difference.
RBob.
Old Jul 6, 2006 | 09:31 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
FWIW Dan, I have a Vortec 330/350 motor, with 9.75:1 compression, comp XFI cam, the EBL and a BBC tb, VAFPR topped at 26 psi. Desktop dyno gives me over 350 horse, and 420 lb/ft of torque. In a few weeks I am taking to the track. With the EBL performance data, I should run a high 13/ very low 14 without the NOS. I also have a 250 horse NOS cheater kit on the car, with the 120 horse jets. All controlled by the EBL. Including fans, shift light. Before I go to the track I am gonna borrow a friends G-tech and see what that says. But, the track will tell the truth!!
Old Jul 10, 2006 | 09:16 AM
DanS's Avatar
The EBL looks great. I couldn't find much information about it when I searched the TBI boards, but I found a ton of info in the DIY Prom boards.
I'm really liking the idea of running two stock tbi units, on a dual quad intake. It seems that this could be done a lot cheaper than the cost of the Holley 4bbl unit. Would there be any drawbacks to this that I'm not thinking of? How much power could this set-up support?
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
jer4251
Sep 27, 2015 09:52 PM
jer4251
Sep 16, 2015 11:29 AM
Djmathis123
Sep 8, 2015 08:42 PM
