fuel injectors?????? help
Old Jul 15, 2006 | 05:53 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
well when i went to start up my car i noticed it running rough. I looked at the carb and only 1 fuel injector is working. i tried spraying carb cleaner into the carb and around the fuel injectors (carb looks new now lol) anyone have any ideas what i can do to tackle this problem. its a 305 tbi. its the part where fuel sprays intot he carb (thats what im talking about, dunno if im calling it the right things) well the left side sprays just fine where the right side is not spraying at all. when i spray some carb cleaner in the right one the engine starts running clean again then quickly goes back.
does this sound like bad injectors?? anyway to properly clean them??? i think there clogged tell you the truth. i dont think they ever been replaced. please help. thanks guys for he help.
Old Jul 15, 2006 | 06:00 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You will probably get more responses in the TBI section. But, check your fuses. You have seperate fuses for each injector in the fuse box.
Old Jul 15, 2006 | 06:56 PM
Engine: V8 350 ci
hey guys i got it. a fuse was out but im glad i used that carb cleaner. runs alot better :P thx for the fast reply, i dont know why i didnt check that first lol.
Old Jul 15, 2006 | 07:03 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
for future reference, you do not have a carbuerated setup. You have throttle body injection *tbi* which is an early form of modern fuel injection.
It looks like a carbuerator but behaves totally different.
Old Jul 15, 2006 | 11:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Therefore we will move this from the Carb forum to the TBI forum . . .
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
