just bought a tuning cable!!
Car: 75 nova 11.15 @ 125, 92 1500 14.60 @97, 95 integra 15.80 @ 91
Engine: 377, 355, 1.8L
Transmission: t350, 700r4, m5
i just bought a cable from the website you have linked and it doesnt work with my new new style laptop because i dont have the 9 pin serial connector so i went to radio shack and bought a cable "serial to usb" convertor and i cant get this to work. can any one help!!
I went thru the same trouble...
Make sure you got a good adapter, the cheap ones don't work well.. I had to buy one of the 25 dollar ones.
After you install the software and plug in the cable check in your device manager and make sure it is set up right.
Mine for some reason wanted to install it'self on com 20 and I needed 1 thru 4 for it to work.
After you reset the com setting if you need to then it should work fine.
Hope this helps..
Hope this helps..
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Sep 7, 2015 01:37 PM
