Quick Question
Quick Question
What is the formal name for the sensor on the passenger side of the motor, below the header flange, near the spark plugs. I broke it while installing headers and I need to get a new one but I bought the wrong sensor. Thanks.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
driver side in cylinder head is temp sensor for dash
on pass sid ein the block way down low is knock sensor
on a 95 and older sbc anyways
This was on the passenger side and it has to do with the water temp because the gauge in the car doesn't work now. I thought this was the "coolant temporature sensor", but it is not. Does that sensor only relay water temp info to the dash or to the computer as well?
Engine: 4.3L Z TBI
interesting
i forget about the electric fans
ive only ever owned one third gen with one
hate them
good luck
hate them
good luck
