Multi-point fuel injection
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
Wondering if anyone has seen or experienced the edelbrock multi-point fuel injections for tbi sbc truck motors. They claim it gives you more power and better gas mileage. I was looking to get a 350 tbi and a computer out of a truck and put it in my 3rd gen and use this system.
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
Unless you buy the standalone and not the one that runs off the stock computer... your limited to 350 hp because of the manifold it has to use. They also said it can't be bored because of it's desing. You might be able to squeeze more power out of it if you use a blower.
Your looking at 20 hp and 20 ft lbs absolute max. People switch to mpfi because it's a more efficient system... better gas mileage(maybe 1 mpg or 2), better off idle tq, better throttle response, and smoother running... not really a power mod tho.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Fast355, Did you do any $OD tuning with the MPFI setup? I will be finishing my motor & MPFI install next week and I know I'll have to do some tuning. I would apreciate any tips or tables that could help my project run ok. This is not a performance deal, just a daily driver that will never see anything over 3500 rpm.
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
