gutless 2nd gear
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
gutless 2nd gear
Hey guys. Was just curious as to if all these 305s are GUTLESS in 2nd gear. its horrible i have no plugs wires cap and rotor and i still feel some sputtering at the top of 2nd. is it time to clean the upper intake? i was also thinking about swapping in a 350, but my question is if it is worth putting another tbi motor in it or goin for a 350 TPI.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Although the LO3 is low on power in stock trim you should not have any sputtering. Have you checked all the basic problem areas? Timing? Fuel pressure etc etc?
I would start there.
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
i havent checked those areas. i will asap though, i mean its not bad but towards the top of 2nd it hesistates a tiny bit. ill have to check those areas. what timing do these cars like to run at?
Car: '90 RS
Engine: 377 LSX
If you have the stock heads 0° to 4° is all you need. Going higher has negative results.
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
what are you supposed to disconnect to set the base timing? i hear there's a big weatherpack connection somewhere. but i don't know what they're talking about.
Car: 91 RS
IIRC it is a light brown or beige wire (single wire) coming out of the Passenger side harness in front of the heater/ac fan motor area.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
