what is this hose?
Old Oct 25, 2006 | 08:18 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
what is this hose?
hey guys, while i was changing the plugs and wires i accidently snapped this brittle *** line. it runs on the back of the fire wall here is the best picture i can get of it the connector is on the left while the line is on the right.
Old Oct 25, 2006 | 10:02 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
okay so what's your question?
it's most likely a vacuum line, either replace it or just tape it up with some duct tape.
Old Oct 25, 2006 | 10:03 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
ya i was just wondering what it was.
Old Oct 25, 2006 | 10:18 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Mine did the same at a similar location. I just took the "broken piece of tubing off and then I re-attached the remaining piece back onto the connector.
Old Oct 26, 2006 | 03:49 PM
DM91RS's Avatar
Car: 91 RS
Are your in car air vents still operatable......one vac hose feeds the doors that operate those.
Old Oct 26, 2006 | 09:21 PM
krisb410's Avatar
IIRC, my vents were stuck on defrost no matter what the setting was set at when that hose was leaking.
Old Oct 27, 2006 | 12:21 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
i didnt even check that. but i repaired it tonight and all vents are working correctly. thanks guys.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
