Tbi pressure help??
Old Nov 19, 2006 | 09:45 PM
90c350's Avatar
Tbi pressure help??
I know that there are alot of threads about this but I have not seen one to answer my question yet. How much pressure can you run without doing mods to your prom?? I am about to do a motor swap with some minor mods, cam,intake,exhaust and ultimate tbi. I have not got into chip burning or tuning yet! Still havent decided the best route to take Ebl,ostirch,Moates all in one etc?? I do have access to a scanner to read the computer while driving. I work at an Autoshop etc. Im just wondering if you can run 14 plus psi without doing Pw mods?? will this affect the idle quality etc??? I have upgraded the fuel pump to a TPI unit and that should be good for 35psi or so. Any suggestions would help greatly. The cam is a comp 260H 440lift 212duration on a 110Lsa. It should be right at about 275 to 280hp at the crank. Or at least this motor made 250Hp without the intake and carb mods with a 600cfm carb. Thanks once again for the great help
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
