500 to spend on mods
Old Nov 7, 2000 | 08:41 AM
jm91rs's Avatar
Ok, say i had 500 bucks to spend on making my car faster. All the mods i have are listed in my signature. What else would you guys recommend doing? I know my car will never be crazy fast, but more than 170 HP would be nice.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood
Old Nov 7, 2000 | 10:07 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Headers, cat, exhaust system. Do the Ultimate mod on your TBI.
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Nov 7, 2000 | 01:10 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Yeah, do the headers (SLP Headers or Edelbrock TES Headers (and get the TES coated) The part number for the TES's are #6872, I am not sure what the part number for the SLP's are. As for the exaust, go with anything 3". Like a flowmaster cat-back (but loose the cat and just use a 3" pipe to connect the pipes where the cat used to be).
Or you could do gears. GM Motive 3:42's or 3:73's and get an Auburn Posi Unit for a 10 Bolt and get make sure you get the same carrier gears size as the carrier in the posi unit. You can decide on either one, headers/exaust is a great mod and so are gears.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
[This message has been edited by 91Bird305 (edited November 07, 2000).]
Old Nov 7, 2000 | 01:50 PM
jm91rs's Avatar
OK...thanks...i already have richmond 3.73's, but if i get headers are they street legal? I have to pass e-check here in OHIO so i would definitely need the cat too. What is the best sounding cat-back system that you guys have ever heard....maybe i should ask in the exhaust board too.
Old Nov 7, 2000 | 05:59 PM
NJ SPEEDER's Avatar
do you have a good posi to go with those gears? slp has torson units for $100.
headers are a good idea. edlebrocks are what i use and i am very happy with them. they come with all the enviro provisions on them. as far as cat backs it is partially a matter of taste. and almost all the header kits come with a new y-pipe to replace the factory junk.
flowmaster and edlebrock both have a deep rumble and fairly soft idle note. the hooker rig is a little louder and the slp stuff is way over priced
all of these kits can match up to you factory cat.
other than the exhaust and the posi chunk if you need it, i would do all the free stuff and the ultimate tbi mods. just save up until you have enough money to get a manifold and all the stuff needed for the install.
lata
tim
91 Camaro RS-LO3,Auto.
14.390 @ 94.99mph
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall), 36mm Front 25mm Rear Sway Bars, Eibach Pro Kit Springs, Bilstein Shocks and Struts, Steve Spohn Rear Rig( all rod ends), Poly Front Bushings, Baer Track Kit Front Brakes W/ Baer Disc Rears, 17x9 4th Gen SS Wheels, Ported TB, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
