What does this mean
Old Nov 20, 2000 | 09:03 AM
PopaPork's Avatar
What does this mean
Hey Thanks for the infro on the misc. page Pablo. I found out that code 24 is "circut fault in vecichle speed sensor" Any one know what that is or how I go about fixing it?? Thanks
89 Rs Camaro TBI
"HM" Air Intake
Pioneer headunit 5200
Polk 3 ways in front and back Pioneer 300 watt amp pushin one 8 Jbl GT
Old Nov 20, 2000 | 12:09 PM
NJ SPEEDER's Avatar
you just hafta chase the wiring for the vss to make sure that it is tight. there is a tech article about disabling the vss that gives all the info on where to fimd the harness that you will need to chase. you may want to clear the code from your computer just to see if it is an actual problem or a false read in the computer. you can unplug your battery to do that but you will then have to reprogram all your radio stations nd clock again.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall), 36mm Front 25mm Rear Sway Bars, Eibach Pro Kit Springs, Bilstein Shocks and Struts, Steve Spohn Rear Rig( all rod ends), Poly Front Bushings, Baer Track Kit Front Brakes W/ Baer Disc Rears, 17x9 4th Gen SS Wheels, Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
