SMOG crap
Old Nov 30, 2000 | 10:39 PM
chevyboy07 91's Avatar
SMOG crap
Hey guys,
can anyone link me up to a good detailed article/pictures about removing/plugging/whatever"ing" all that crap on (your left from standing in front of the car) side of the motor. It's all that AIR crap. There's hoses everywhere. Also, the removal of the smog pump and any change in belt sizes etc. Basically. I need the works. Thanks,
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Dec 1, 2000 | 01:59 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Some of those "hoses" are affiliated with your heater controls.
The metal lines and such are the stuff you want out of there. I would be highly interested in this also, and if nobody goes about writing it. If you can wait, I hope to rid my engine compartment with the emissions over christmas break, most likely early January. If when I do so, nobody has done it, I will document everything and write the article in the same manner as the open element. Pics and text.
IM: snflupigus | ICQ: 96787192
Open Element Tech Article
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,160 Deg. Thermostat,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Dec 1, 2000 | 02:56 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
There isnt much to it guys, just remove it all
the only thing you need to be concerned about plugging are the holes in the manifold if you choose to remove the air tubes. They take a 1/4 inch pipe plug
the length of the belt is a 968K6
the routing is detailed in the tech section of the website
Alex, are you going to fuddruckers sat. night? if so, then ill be there and ill show you the works on that
Old Dec 1, 2000 | 03:21 PM
I wasn't planning on Fudd's but I can stop by for a little more edu-macation.
Thanks man,
Later
Old Dec 2, 2000 | 01:25 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Isn't there some rewiring that you have to do as well? My AIR and Smog pump is gone but I didn't do that, my previous owner did. And it looks like he did a little rewiring as well. Might want to look into that. Maybe that was to keep that SES light from coming on as well as other warning lights.
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
jaridjohn
Oct 5, 2015 07:01 AM
