Fuel Presure Reg.
Old Dec 6, 2000 | 11:09 PM
chevyboy07 91's Avatar
Fuel Presure Reg.
hey all,
I saw an adjustable FPR for TBI's in Summit from JET. Do you recommend it???? Is this what you guys are running? Can I use this on a carbed set-up also?? I run both set-ups from time to time. I want to be able to use it for both.
Or should I go for a Mallory or something like that?
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Dec 7, 2000 | 02:00 AM
JPrevost's Avatar
Car: 91 Red Sled
You can make your own real easy. There is an article in the tech section that talks about making the stock pressure adjustable.
, Jon (91 RS too many mods to list)
Old Dec 7, 2000 | 05:05 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
or just go with an external like what i have, i can swap to a carb in like 5 mins if i wanted to
Old Dec 7, 2000 | 01:03 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Pablo:
How did you bypass the factory one on the TB? I like your idea and would like to get more info and a pic maybe :=))))
Brian
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
