Thinking about a 350 TBI
I've thought about getting a 350 TBI truck engine to swap out my 305 TBI. Would that be a compatible with my current computer and tranny? Only mods I would do to it are maybe Edelbrock intake and headers along with my planned open element setup (as soon as my cowl hood from unlimited comes in).
Not really after a pavent pounder, will be getting a LS1 Formula WS6 in a year and a half. So my 88 will be continue to be my nice daily driver (and get more compliments
EVILFACE
"Never scared of the things men fear"
http://www.evilface.com/evilscamaro.htm
88 Camaro
Stock 305 TBI Auto,
Flowmaster Muffler, Full 3" Exhaust, B&M Megashifter
Runs A Blistering 16.5 @ 81.5 mph
EVILFACE
88 Camaro
Stock 305 TBI Auto,
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i have a 350 in my car, with a pretty lumpy cam, and i STILL have the stock computer and chip and my car screams, even with the crappy rtear end i have (open 2.73s). the trayy shoudl definitely bolt up, and so shoudl all the accesories. remember, the only difference between a 305 and 350 is on the inside of the block, so everything for the most part should fit. everything from mine swapped over without any problems.
i would recommend staying way from the edelbrock intake if you plan on getting a bigger throttle body. i would just get a carb intake and get an adapter, they work a lot better with the bigger throttle bodies. but, if you want to keep the stock one, then by all means go for it. they are basically a "takle one out and put teh other in" swap...really easy.
go for the edelbrock headers. i had them before my current stainless SLP ones, they were nice. the only reason i got rid of them was that i wanted some without the A.I.R. tubes.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-brian
Brian's 1991 RS
