Another one of my great questions
Old Dec 17, 2000 | 03:39 PM
Holland's Avatar
What would you think would get more air flow to the throttle body a little better. the dual snorkle, k&n open elemental, or open air element that edelbrock makes?
Old Dec 17, 2000 | 04:31 PM
BLUE92RS's Avatar
The open element but it is hot air which does less for your performance. I would do the open element and leave the snorkel so that it blows some cool air inthe area then go to a junk yard pic up another snorkel and hook it up on the other side for even more air
Old Dec 17, 2000 | 10:22 PM
Basett Racing's Avatar
Has anyone tried using a "carb hat" w/ a cold air tube - Kinda like the set-up on a late model 4.3L V6. I've seen the "hats" for supercharged carbed engines, but I've never seen one being used w/o the supercharger. I wonder if getting one of these, then running a peice of 3" aluminum conduit or something similiar in plastic such as the black PVC pipe away from the engine and picking up cold air from one of the cutouts on the inside of the driver's side fender and using a K&N cone filter would be more effecient than an open element since it would be cold air w/ very little restriction. What do you guys think?
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
Old Dec 18, 2000 | 10:11 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
please search and check the arcives. Obviously the open element flows more. The debate will always be open for performance loss of hot vs cold air. I have done some research. It seems that if you are racing for a while, like say, nascar. then hot air is bad. However, if you are doing autox or stoplite or dragracing, then the hot air isnt gona make jack sheet of a difference. My research mainly included looking at tons of pictures of racecars, and racing engines, etc..
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
