305 Ground Locations
Hey guys, I just installed a GM Goodwrench 305 into my Camaro. For some reason the car isn't pulling enough amps from the battery. I've pulled the fuses, tested voltage at the battery, recharged the battery to 12.1 Volts and still no luck. I was wondering if anybody had a picture of where the Ground Terminals were on this engine. If you guys have one or could take one it would really be a big help to me.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Like he said, there are studs, or should be studs, installed in the rear of each head for the wire harness. The front of the pass. side head also has the ground that leads to the battery.
colton_carlson
Mar 8, 2019 12:21 PM
