Help: My radiator fan wont turn on!
Old Apr 2, 2001 | 01:11 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Heres the problem: my car will overheat (way past redline) in traffic or at idle unless I have the AC on. When I turn the AC on, the radiator fan turns on and cools the engine down quickly. Regular driving, there is enough air coming in from the air dam to cool the car down. I didnt want to rely on my AC to cool my car down, so I tried to fix it. I went under the car, and noticed that the connector connected to the fan switch was lose, I pulled it out, and noticed it was completely broken. I went ahead and made sure the wire itself worked, so I put the ignition on, grounded the wire, and the fan turned on.....that means the fan works and the wire leading to the switch works right? I went ahead and replaced the fan switch with a new stock one (wrapping it in teflon tape) and replaced the connector with a new connector from the dealership. Made sure again that my new connection was true by grounding the new wire and it worked....hooked it up to the new switch and locked it in place. Started the car up, let it reach all the way to redline again.......and still the fan didnt kick in......anyone have any ideas as to what else it could be? Thanks
http://users.ticnet.com/mult68
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cat Coming
More to come.
[This message has been edited by mult68 (edited April 02, 2001).]
Old Apr 3, 2001 | 12:51 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Moving to general tech, you will get better responses i think.
snflupigus
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Chuck84TA
Jul 15, 2016 09:05 PM
krisner89
Oct 10, 2015 06:03 AM
LittleFranks
Sep 17, 2015 12:22 PM
