TBI fuel pump question
Old Feb 1, 2007 | 08:02 PM
92Forumla's Avatar
Car: 2017 2.0T Camaro / 1989 IROC
Engine: LTG / L98
Transmission: Tremec TR 3060 / 700R-4
I did a but I couldn't find what I needed. My fuel pump called it quits and I was wondering if I should replace it with a TPI pump. I have a open element, Ultimate TBI, deleted smog pump and catback. Will a TPI pump affect anything?
Old Feb 1, 2007 | 08:26 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
No tpi pump will work great for your set up.
If you go to cam, injectors, etc. a walbro 155 or 255 would be in order.
Old Feb 1, 2007 | 08:34 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Im wrong..
Old Feb 1, 2007 | 09:03 PM
92Forumla's Avatar
Engine: LTG / L98
Agreed Im not looking for 45 horses from a fuel pump, I'm just saying if I throw one in there now, It'll be one thing off the list when I put a cam in.
Old Feb 1, 2007 | 09:29 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
how much power can a 190lph pump handle? is a tpi pump bigger? how much can i tpi handle? for either do i need a fuel pressure regulator? or will stock do? sorry for all the questions
Old Feb 1, 2007 | 09:33 PM
92Forumla's Avatar
Engine: LTG / L98
Hijacker.......j/k
Old Feb 2, 2007 | 11:29 AM
Engine: LO3
sorry it just seems easier to post it in here because theyre all already helping you. BTW hows your deleted smog pump was it easy to remove? make any difference other than be able to see a second valve cover for the first time?
Old Feb 2, 2007 | 12:51 PM
92Forumla's Avatar
Engine: LTG / L98
It worked out great. I used a Dayco 923K6 belt and put on some chrome valve covers while I was at it. It looks great, ill get you a pic.
Old Feb 2, 2007 | 01:23 PM
Engine: LO3
is that belt used for air conditioning and altenator if so i need the size because im deleting mine when i put my headers on soon.
Old Feb 2, 2007 | 07:06 PM
92Forumla's Avatar
Engine: LTG / L98
The accessories I have left are the alternator, water pump, power steering, crank and air conditioning, I also DO NOT have underdrive pulleys, I used a 923K6 belt and it worked great.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
