Lobe Centerline
Old Apr 16, 2001 | 10:41 PM
scott92RS's Avatar
Car: 92 Firebird
Engine: 350 TBI/LT4 cam
Transmission: 700R
Lobe Centerline
What is the minimum lobe centerline for 350 that is compatible with TBI computers?
Old Apr 17, 2001 | 12:35 AM
SCRA rules!'s Avatar
If you mean Lobe Separation Angle (LSA), I would say about 112 degrees. I have 110,and it works, but sometimes is a little finicky and the vaccuum can be marginal depending on the duration and rest of your combination.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
Old Apr 17, 2001 | 12:38 AM
Brent's Avatar
It's not so much a matter of lobe centerline as it is lobe overlap.
The stock LO3 centerline is 108. Because the duration is so short there is no overlap.
Duration and centerline both affect overlap which affects vacuum and idle quality.
Low vacuum combinations are harder to tune EFI wise.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
