O2 Sensor ?????????
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
O2 Sensor ?????????
I am replacing some of my sensors while I have some things apart.....Is there a better than stock O2 sensor??? I heard something about a wide spectrum (band)sensor, but cant find any info on it.....Cant someone tell me if this is true, and if so a breif explanation on it......Thanks so much..Tom
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The wideband O2s typically require a special closed loop controller, such as the LM1 from innovate, to regulate the temperature of the sensor, and have a much broader range of output. Theyre what youd use for tuning the engine.
The stock narrowband sensor just goes to around .9V above 14.7 and 0-.100V below 14.7, and just tells the computer if teh engine is above or below stoich. The best sensor for the car is probably a standard heated delco O2.
Car: 89 RS, 92 Z28
Well, thank you for the info...I am not very up on all this computer stuff..
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree 100%. Stay away from Bosch 02 sensors as they tend to make a stock tune run slightly rich. Stick with plain jain AC delco. Around here most parts stores only sell Bosch so I am forced to go to the dealer to order them.
Car: 91 RS
Engine: 350 TBI
HoosierinWA
Oct 7, 2015 10:15 AM
