NOT GOOD
Old May 3, 2001 | 10:47 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
NOT GOOD
I made a cold air/ram air sort of setup on my 305 TBI. I drove a while and remived the air filter to see if the intake lets in more dirt. I found that my cold air intake lets gravel into the housing. It did not get past the filter, but I need to solve this problem now. Any suggestions besides scraping the whole thing? I was thinking screens.
Old May 3, 2001 | 11:52 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
sounds like you solved your own problem.
Old May 4, 2001 | 12:03 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Yeah, just put in some screens. You should be able to find something at home depot like screen door material and use that...
Mike
Old May 4, 2001 | 01:35 AM
KissmySS's Avatar
A screen from a home depot or somthing like that would be perfect!! I had the same problem with my home made ram air then i just bought some screen(like the one they use in doors) and it kept all that stuff out.
91 camaro 305 Tbi(I love it!!!)
*Teal green
*z-28 Grille(red bowtie)
*Z-28 Fog lights
*tail light black outs
*limo tint
*Polished 16'z-28 rims(In side groves too)
*Flowmasters,flowtech headers with cut out
*K&N with dual snorkal ram air(in air dam)
*Accel,wires,cap,rotor,coil,rapid fire sparkplugs
*And all the free tbi mods
*B&m shift kit with hurst HotShift fuild and trans cooler
*Best Et 15.34 at 90 mph
*Neg traction and 2.73 don't help very much
Furture mods(Limited slip with 3.42s, mallory ignition box,ram air hood,and...........
Old May 14, 2001 | 01:26 AM
One Eyed Jack's Avatar
I was goign to do that with my car, and for the pre-filter to use an old thin sock or panty hose. A screen would be nice but bugs would clog it. A sock you could remove and wash or put a new one on it in a matter of minutes. They both have their advantages.
Btw what did you construct your cold air intake out of? I was considering aluminum downspout drain gutter stuff. Its like 2" x 3.5" square and would fit nicely. I'm just worried i'd get it too close to the belts!
1992 Pontiac Firebird
- 5.0L V8 TBI
- Automatic Trans
Old May 14, 2001 | 08:16 PM
TZFBird's Avatar
Engine: 327
Jack
I used an aleuminum dryer vent hose. I also didn't run it up past the belts. I removed one of the horns and ran it up through the driver's side fender. I'm not sure if it has too many bends in it or what. I would think it slows the air down more. Well, it's better than the stock, but I will probly just use some screen. I'm not too picky about bugs. As soon as I can figure something out, I might run the hose between the belt and fan, but for now, it wors good. I hope that gave you te info you needed.
Old May 14, 2001 | 09:50 PM
That was my first idea, but it seemed a bit clunky.
- 5.0L V8 TBI
- Automatic Trans
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
