Hesitation 92 camaro
Old May 15, 2001 | 10:25 PM
Rallyssport's Avatar
Everytime i barely give it gas it wants to die, and sometimes does. Its hard to explain how much throttle i give it but its kinda like when your in a taco bell drive thru and there is a car infront of u and u want to pull up just a bit. Get what im saying? But when i give it anything over what i just explained it dont do it. Got any ideas?
Old May 16, 2001 | 09:18 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
stick, maybe you arent letting the clutch out right. LOL
just kidding. sounds like coil or something related. check your plugs, and how is your mileage?
Old May 16, 2001 | 09:48 PM
I just changed my plugs not to long ago. Havent checked my wires or coil...Think it could be one of them?
Old May 16, 2001 | 10:43 PM
steve8586iroc's Avatar
Check you tps sensor you may have a bad spot in it that drops the volage to 0 when you just crack the throttle a little.
Steve
Old May 17, 2001 | 10:29 PM
Im not good with sensers...whats the tps senser?
Old May 17, 2001 | 11:22 PM
Throttle position sensor, it's located on the opposite side of the throttle body from the throttle cable and it has aaan electrical plug with three wires on it.
Steve
Old May 18, 2001 | 08:33 AM
snflupigus's Avatar
go to the tech section from the home page of thirdgen. read the adjusting your tps article.
db057
Aug 22, 2015 08:17 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
