New to LO3, quick question
Old Feb 25, 2007 | 08:55 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Just bought a new car with an LO3 intake, and I am doing some repairs. I see the EGR vac line was disconnected from the car. Since I am trouble shooting I need to hook this back up. The Diagram on the hood appears to show that it should hook strait to the TB. I am not finding a port that it should plug up to. Is there one, or is the diagram mis-leading and it T's off from something else?
Old Feb 27, 2007 | 05:12 PM
ThEWhitebirD's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 Tbi w/lt4 hot cam
Axle/Gears: torsen 3.42
should be 4 ports on the TB. one on the back facing distributor for map sensor, 3 up front one for egr(passenger side), PVC (bigger one in the middle) and Purge canister (drivers side). the egr should have a hard plastic line that is pre-bent to take the shape of were it should connect too. but yes the egr is directly connected to the TB no T'ing off. maybe someone before you changed the TB with the wrong one so they left the egr disconnected?
Old Feb 27, 2007 | 07:37 PM
Dale's Avatar
Engine: 350 S-TPI
Did some searching on here and came up with same diagram as on the hood(not factory hood).
I have so many vac lines.. 2 to perge canister area, 2 to hvac, map, pvc, egr, aircleaner. I think 1 more, and I'd like to have a piller pod vac guage too.
The diagram does not show any HVAC hooking up to the TB. And some of these pre-bent lines have been routed to what I guess is the wrong stuff and are no longer shapped right. The TB has just as many ports as the diagram shows, but as I said, no HVAC hooking up to it. Where does it get vac? Why 2 Perge canister lines?
Anyone have some high res pictures of a stock setup they could email me?
Old Feb 27, 2007 | 09:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Take a look at the LT1 cam digest in the stickies above. There should be a picture of the stock TBI unit with all of the vacuum lines labeled accordingly.
Old Feb 28, 2007 | 12:21 PM
Dale's Avatar
Engine: 350 S-TPI
I took a look at that, and that is same as diagram on the hood as well.
I guess I'm having problems with where/how the accessorys like cruise and hvac should be hooked up. What do they tap into?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
