Last Timing Question
Old May 31, 2001 | 02:37 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
OK the beast lives the timing is set on TDC and its running fine however I need to set the base timing. I pulled the wire at the passenger side firewall and the car dies..... What is the process
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old May 31, 2001 | 02:45 PM
FastBroker's Avatar
If it dies, you probably don' thave enough initial timing to get it to run with the timing control disconnected. Try advancing the distributor a bit by hand (like 10deg) and retrying the whole process. If you keep advancing the distributor and the car runs but then stalls when you disconnect the bypass circuit, you have a bad ignition module. you should be ok, though, by advancing a bit. Counerclockwise while looking down on the distributor to advance, BTW.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
