Fuel Pump UGH!!!
Old Jun 5, 2001 | 08:35 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Fuel Pump UGH!!!
OK OK here we go again, I guess the timing is right but I still had problems. Well its looking like me Fuel pump may be bad. When you hit the gas it dies....It will also backfire....amd my fuel pressure gage showes about 9 to 12 PSI and sometimes it will not pump up the gage.
#2 if the pump is bad can I install an inline pump and disconnect the in tank one and let the fuel pull through or do I have top drop the tank and do the dirty...
Thanks so much
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old Jun 6, 2001 | 10:08 AM
Kyle F's Avatar
Brian, I dont think your fuel pump is bad. When the Fuel pump went out in the 88 Trans AM that Terris dad had it didn't act anything like yours does. Plus you are getting plenty of fuel at the INjectors, and you said the guage was bad.
Are you sure the Timing is set right? Are you positive you don't have a bad chip? Are you sure The ECM is OK?
When the fuel pump went out in the Trans AM it would have trouble Ideling and sometimes wouldn't start. Ofcourse this was on a TPi system, but I woul think the symptoms would be the same. Though if you could keep the RPMS up for somereason it would run. Go figure. I would sudject getting a different guage and testing it to make sure.
As for disconecting your in tank and instlling an inline, my thought is no. I might be wrong but here is my thinking. The pump in the tank pums the fuel out and pushes it to the motor, though if its not pumping it seems like it would restrict the flow very badly and nomatter what kind of pump you put outside of the tank it would not be able to get the fuel to pump because the old pump is blocking the fuel flow. Now you could take the old one out and put an inline in close to the tank. You have to have you pump close to the tank because electric fuel pupms push better than they pull.
Maybe you fuel filter or sock on the pump is cloged. I would chec your fuel filter first, if it fine and you really think its the Fuel pump then I would say the next step is to drop the tank.
I know it is a lot of work, but I have time after today to spend as much time on it as you would like, as Long as I can do my laundry at your house!
I mean we already had the rear end out once right how hard can it be to do again? Though we will have to figure out away to drain the old gas out of the car.
Here is another thought I just came up with? What if the gas in the tank has went bad from stting for so long? The computer would be seeing a lot of knock and retarding the timing back to where tha car would barely run. DO you think this is why we had to advance the timing so far the first time we put the distributor in? Something to consider. I will give you a call later tonight.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 6, 2001 | 12:03 PM
Kyle........I said the fuel guage was off not whe the relay kicks on the needle does not even move. Yeah its not all of our problems but its one big one. Update Edit....took off fuel inlet and no fuel when I hear the pump come on....
Brian
1989 Camaro RS
[This message has been edited by Brian Felts (edited June 06, 2001).]
Old Jun 6, 2001 | 07:08 PM
JPrevost's Avatar
Car: 91 Red Sled
Did you change the fuel filter . Give me a call, I'm free this whole weekend if you need some extra hands.
, Jon
, Jon (350 TBI!)
91 Red My website
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
