92 RS Idle Speed
Old Jun 15, 2001 | 02:08 PM
Rallyssport's Avatar
92 RS Idle Speed
I have a 92 RS 305 TBI and i have my idle set at 900 rpm in park. The reason I put it up that high is because i have underdrive pulleys on and everytime i would start it it would die. so i uped the idle speed and it works fine. I was wondering if 900rpms in park would hurt anything?
Old Jun 15, 2001 | 02:57 PM
Saint89's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rallyssport:
I have a 92 RS 305 TBI and i have my idle set at 900 rpm in park. The reason I put it up that high is because i have underdrive pulleys on and everytime i would start it it would die. so i uped the idle speed and it works fine. I was wondering if 900rpms in park would hurt anything?</font>
I don't think you'll hurt anything by that, just eat a little more gas. I think mine probably idles @ 750 in park, warmed up. I'd actually like to raise it, because it idles SO slow in drive, like at a stoplight that sometimes it'll stall. Is is easy to turn it up? Is there a screw?
Old Jun 15, 2001 | 03:21 PM
buddman91rs's Avatar
yes, on the drivers side of the throttle body where the throttle linkage is you will see it resting on the tip of a screw. there is a plastic plate over the other end of the screw towards the front of the TB. you need to find something to poke through the plastic peice and pull it out. after you get that out you should be able to see the head of the screw.......turn it right for higher idle and left for lower idle.....have fun
1991 RS LO3
Confucious say: man who stand on toilet is high on pot, confucious also say that man who go to bed with itchy butt wake up with stinky finger.
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
