poping exhaust on deceleration
Old Jun 15, 2001 | 07:00 PM
rsilver's Avatar
I still need to work on a new chip for my swap, but does anyone know what would cause
popping (almost like a backfire but not as loud) coming from my muffler when I decelerate or shift gears? It pulls very strong but when you let off it pops. Any thoughts are appreciated..........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Jun 15, 2001 | 08:23 PM
BadBowTie's Avatar
it could be that your timing is advanced just a bit to much.
Old Jun 15, 2001 | 11:42 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Could be oxygen getting into the exhaust. A bad header gasket, exhaust leak, ect.
-Mark W.
'88 SC Camaro /w 305 TBI
Old Jun 16, 2001 | 01:05 AM
JPrevost's Avatar
Car: 91 Red Sled
You obviously have unburnt fuel so you're either a) Running rich, or b) Cylinder missing. I'm going to go with a) since you said it pulls strong. Do you have the AIR system still hooked up? What about the CAT? What ecm are you running with (stock 8746 or 7747)? Either way, if the car isn't running rich then you'll want to edit the deceleration table. It sences the TPS position over time and if you let up real quick it'll look at the MAP pressure etc. and cut off the fuel and ignore the engine rpm. Check your spark plugs, I'll bet they show you're running rich all the time.
, Jon (350 TBI!)
91 Red My website
Old Jun 16, 2001 | 01:30 AM
rsilver's Avatar
JP, the air system is hooked up, I am running
a cat and the ecm is the 8746. The plugs look all right to me, maybe a little rich, but not a ton.Your comments on the deceleration table is very helpful.The cop chip is for an automatic and I have a t-5 so there is probably a difference on deceleration. I am going to try my 305
thermomaster chip and see what it does to the problem.
I think I also have an exhaust leak.I just noticed it tonight, very slight either by the header or header pipe. Still not sure.
Anyway, thank you all for your help.I got 1100 miles on it and so far so good.......bob
Old Jun 16, 2001 | 06:33 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
rich with exhaust leak is usually the prob when it comes to that. my 69 does it horribly. cuz its carb, and the exhaust is rusted to hell and gone.
Old Jun 17, 2001 | 12:11 AM
JPrevost's Avatar
Car: 91 Red Sled
No prob, just get all the things you know that is wrong fixed. Then move onto the more complicated stuff like eprom tables etc. It's usually the simpliest things that make the car run the worst.
, Jon (350 TBI!)
91 Red My website
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Youngs92
Sep 23, 2015 11:29 AM
greenyone
Sep 2, 2015 03:39 PM
