Fuel Pressure setting?
Old Jun 26, 2001 | 08:32 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey I made my fuel pressure regulator adjustable (thanks tech article) now I am wondering what is the best PSI for my mods.....What have others done??
Thanks everybody! Its starting to come together
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 27, 2001 | 07:57 AM
Brent's Avatar
The best Fuel Pressure is one high enough to support your WOT fuel requirements.
Old Jun 27, 2001 | 03:14 PM
My305camaro's Avatar
I run 12psi. I run it all the time with no problems.
1991 Chevy Camaro RS TBI
Old Jun 27, 2001 | 04:04 PM
Hey my305camaro what mods are you running. I am going to try 12psi and see how it goes.
Brian
1989 Camaro RS
Old Jun 28, 2001 | 12:43 PM
Brian here's the mod list: Edelbrock TES headers, high flow cat w/3in Flowmaster catback, Full MSD ignition system, Bosch quad4 racing plugs, 160 stat W/custom chip, Ultimate TBI mods, open air 14X3 K&N, and as many suspention upgrades as my wallet has allowed (too many to list). I did the suspention work first and I'm just now starting on the engine.
Old Jun 28, 2001 | 12:52 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
My305camaro, I plan on starting with suspension as well. If it's not too much trouble could you list all your suspension mods on the board or email me at soulbounder@yahoo.com ? I just want to get ideas and such. Thanks.
Old Jun 29, 2001 | 12:56 AM
Here it goes: subframe connector(well worth the money), adjustable panhard rod (lakewood), all poly bushings front & rear (energy sus.), 24mm rear sway bar[front stock size], traction-action lift bars (from Lakewood), tie rod sleeves (hotchkis), strut tower brace(edelbrock), Sport Springs (hotchkis), KYB Gas-a-Just shocks/struts, and an alignment config that my local performance shop customized for my driving style & mods (specs I don't know). My car will easily do 55-60 on any 25 mph off-ramp as long as it isn't raining. My wet weather performance is worse because of the over-steer created by the big sway bar out back. I run 245/50/R16 Firestone Firehawk SVX's. The car also hooks up better but that doesn't help me alot because the engine is still pretty stock. Hope this helps
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
