Fuelpump (Caprice)
Old Mar 13, 2007 | 05:12 PM
Jens J's Avatar
Fuelpump (Caprice)
Hi, Do anyone know if it is possible to use a Walbro pump whitout modificationes and if so what partnumber? My stock pump is getting weak and i am building a lo5 whith ported 193s, cam, 454tb ,edelbrock intake, headers and dual 2.5 exhaust so i think i need a better than stock pump.
Thanks Jens
Old Mar 13, 2007 | 08:46 PM
roadmasster's Avatar
Car: 93 Buick Roadmaster
Engine: 350 TBI
Transmission: 4L60
Axle/Gears: 3.08
I just put in a Walbro FPG002 in my 93' Buick Roadmaster from http://www.autoperformanceengineering.com, it says 85-92 GM universal and it went in rather easy with minor modifications, I had to trim some plastic off the bottom of the holder since the stock pumps inlet was offset and the Walbro was centered, and also had to trim some plastic off the hole in the lid of the holder for the larger connector to the Walbro. Also I had to splice in the provided wiring harness since the connector on the Walbro was larger than the stock. This was my first pump I've done and it was really easy I thought.
Old Mar 14, 2007 | 09:49 AM
Engine: 350 TBI
Transmission: 4L60
Axle/Gears: 3.08
Also forgot to mention that I used this page as a reference as I worked on my pump http://www.dragtimes.com/forums/lofi...php?t3412.html , also while your at it you should install the Bradley fuel gauge corrector if you haven't already http://impalassforum.com/cgi-bin/ult...352;p=1#000004 its really a quality piece and took a whole 15 minutes to install and well worth it.
Old Mar 14, 2007 | 01:43 PM
Jens J's Avatar
Thank you very much for the help.
Best regards Jens
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Caspar
Jun 19, 2016 11:19 PM
CatmanFS
Sep 19, 2015 09:00 AM
BLK87Z
Sep 18, 2015 11:29 PM
Strick1
Sep 6, 2015 10:38 AM
