TPI fuel pump in a tbi car?
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Want to switch from TBI to TPI...so I will be getting a new Walbro High-Pressure
255 ltr/hr pump.....however...About a year ago I got a flowmaster exhaust installed at a muffler shop...and they welded everything....I was thinking of taking my car to a shop...and have them do the fuel pump swap....so they can weld the exhaust back together..and i wont have to deal with it...first..it shouldnt be THAT much money in labor should it? Second...will my TBI system beable to handle the new fuel pump....it'll only be temporary (from the shop back to my house)....I am a bit confused because I know TBI uses like 12psi fuel pressure...and TPI around 40 or so...but will the TBI regulator do its job and take it all the way down? Thanks for the info. Also...any recommendations as to where I should take it? Should pretty much any shop beable to do it? Should I be there and watch and make sure they do everything right?
http://users.ticnet.com/mult68
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cat Coming
More to come.
[This message has been edited by mult68 (edited July 06, 2001).]
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That is a good ? I want a new fuel pump too but I am afraid if I do it to soon before any major mods, that it will flow to much.
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Hooker 3" Areochamber
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/28,000 Pampered miles
(Still have the original wiper blades)
1990 RS 305 TBI T-5
Engine: 305 TBI
Well after a bit of research (actually a lot) it SEEMS as if any fuel not used is just returned back to the tank....but I still dont know if the dramatic difference in pressure will affect the TBI system...anyone???
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Been there, done that. Using the Walbro 255l/hr pump with no problems. The pressure regulator in the TBI will work just fine. While you're doing the swap, you might as well put a fuel pressure gauge in too...
Darth Steve
Darth Steve
Car: 91 Red Sled
I'm going to be getting the Walbro this week. I'm pretty sure this stock pump isn't giving me enough fuel pressure at WOT.
As for high pressure pumps etc. it doesn't really matter unless the pump was specifically designed for high pressure only. The more important factor is flow. The fuel that doesn't go into the engine will return through the return line and if it flows well then the fuel lines will stay cooler. That's a good thing. Just make sure you watch the fuel pressure.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Engine: 305 TBI
So how would I install an electronic pressure guage on a tbi car?
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
