Anybody used Ramairbox.com's dual snorkel?
Old Jul 18, 2001 | 11:24 PM
My305camaro's Avatar
About to order a dual snorkel setup from www.ramairbox.com and I was just wondering if any of my TBI brethren are currently running their product. Looks like a good deal, 4in. inlets, smooth tubing, no thermac garbage. Any feedback would be great!
Thanks!
1991 Chevy Camaro RS TBI
Old Jul 19, 2001 | 09:43 AM
Crack Monkey's Avatar
I don't have it, but was also considering it for my Caprice 9C1.
Old Jul 20, 2001 | 12:13 AM
I'll take a couple days of no responces as a no. Once I make the order I'll have to post a reveiw off this high flow unit. The e-mailed me today and said their setup for the 82-92 TBI flows over 780 cfm and has a ram effect of 2-4 psi at 60 mph. Sounds good but what does it do on the track? They say 4 tenths over the single snorkel...we'll see.
Old Jul 20, 2001 | 12:57 AM
JPrevost's Avatar
Car: 91 Red Sled
It's like a open element but with cold air and ram air advantages. For the price I would probably not get it if I had a stock Lo3. If I had something on the more radical side then I would consider it as an alternative to the conventional open ele. One setup that I want to make is an SS hood with an dual snorkel setup and an extream flow top. I would have it well insulated and I think that would be the best of both worlds. High flow, cool, and ram air if you do it right.
Do let us know how you like the setup.
, Jon (350 TBI!)
91 Red My website
Old Jul 20, 2001 | 07:24 PM
rsilver's Avatar
A couple of things to think about. I called pierre at Ramair and for a 91 camaro you have to install a smaller coolant recovery tank and a few other mods I can't recall.
YO gotta figure out where you are going to put the snorkles to get cold air. They are 4" so you can take out a headlight on each side but the stock snorkle scoops that mount under the hood don't flow much and are only 3" as I recall.Let us know if you do this and what you end up with. Also check the archives there is another thread on this..........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
