SINGLE PLANE MANIFOLD- WORTH USING!!!!!
has anybody tried using a single plane manifold like the weiand x-celerator
manifold and adapter plate for tbi and notice any power increases throughout the entire rpm without sacrificing any bottom end.
i was considering to use one on my stroker 383 because my existing manifold has been planed and is not fitting correctly on the heads. this is in a truck has all the aftermarket goodys. i can get this manifold cheap and don’t want to loose my pulling power. the engine presently has the performer intake c/w holley adapter and 2” 454tb. i had to double up on the intake gaskets to fit the manifold.
is it true the tbi on a single plane doesnt require the vaccum like a carb engine?
383 stroker, 64cc 23deg trickflow heads c/w edlebrock performer intake and adapter, cam is an extreme 4x4 comp. Cam. 12-235-2 grind ( .447/.462 lift, duration 210 218 lift @50, 111 lobe separation) . unit has hypr. Flattop floating pistons, eagle cast crank, 5.7eagle rods. 10.2:1 comp. Headers c/w 2.5” flowmaster exhaust. 16147060 pcm, $85def
454tbi 80lbinjectors
Car: 91 Red Sled
It's true that TBI isn't dependant on vacuum as much as carb. TBI can make adjustments with a custom eprom if there is THAT much of a lack of vacuum. It might be hard to see it but TBI is just like TPI except TBI is a wetflow. I would go with single plane if you don't plan on ever going with a carb setup. The flexibility of EFI is great! Just be careful of cam lobe seperation and you're good to go.
I personally went with an RPM intake but I think it would have been smarter if I had gone with a single plane.
There are a few guys that use single plane and TBI (Pablo, maybe more) and they like it. Don't go with a victor jr. just get the torker 2 and be happy!
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
why was this moved here? He already put the same post in TBI. He wanted more opinions. geeze
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
:Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
The x-style intakes are outdated technology and dont work well. There are much better single planes out there but for that motor if low end torque needs to be maximised I'd go with a dual plane or a long runner multi-point setup... TPI makes for a great truck intake.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
GM big block 2bbl TBI on truck 7747 computer
1988 T/A,
LT1Formula
Oct 8, 2015 08:34 PM
