OH MY GOD!!! IT'S ALIVE!!!!
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
For those of you not keeping up with my previous posts, I had trouble setting the distributor right to get my 355 started. I messed around with it tonight, and actually got it running. Turns out I was 90 degrees out, which explained why I backfired out the intake when I stabbed the dist. one way, and then out the exhaust when I stabbed it the other way. I just wanted to say thank you to all who have helped me, given me advice. I wish I could let you all drive my car, since you guys are the ones who helped me get it running. It says a lot about the people on this board-- willing to help out others just for the sake of doing so. That means a lot to me (sniff, sniff)
. Thanks guys. BTW, it sounds mean!! I do have one question, which is necessary so this thread doesn't get locked. I am running stock fuel pressure on 65# injectors. Is this enough for a car that has a cam w/ .480/.480 lift, 1.6/2.0 heads? I am playing with fire here? Will it run too lean? I have some 454 injectors, should I use these instead? Opinions? thanks again to all who have helped. I wish I could thank each of you personally, and buy ya' a cold Lone Star (State Beer of TX). It's been 8 months since I have heard my car run! I am very happy. This is my first project.
Havin' a Cold One,
James
. Thanks guys. BTW, it sounds mean!! I do have one question, which is necessary so this thread doesn't get locked. I am running stock fuel pressure on 65# injectors. Is this enough for a car that has a cam w/ .480/.480 lift, 1.6/2.0 heads? I am playing with fire here? Will it run too lean? I have some 454 injectors, should I use these instead? Opinions? thanks again to all who have helped. I wish I could thank each of you personally, and buy ya' a cold Lone Star (State Beer of TX). It's been 8 months since I have heard my car run! I am very happy. This is my first project.Havin' a Cold One,
James
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I would think your imjectors are fine......However I would pump up the fuel pressure to make them flow a little more.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Brian
1989 Camaro RS
lt1z350
Sep 29, 2015 01:50 PM
