dyno numbers
Old Mar 31, 2007 | 12:14 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
dyno numbers
Hey does anyone have any dyno numbers from a bone stock TBI 305 powered f-body? i just ran mine on the dyno yesterday at school. 157 HP @ 4250 and 233 TQ @ 2900, with the mods in my sig. just interested in how much i picked up with the headers back pipes and K&N filter. those #'s are at the wheels btw.
Old Apr 1, 2007 | 11:20 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: dyno numbers
I have read about several people making 140 to 145 rwhp on entirely stock TBI LO3 engines in either Fcars or Bcars, in both cases running thru a 700R4 (aka 4L60) transmission. That's about right given the stock 170 fwhp rating and the 15 to 18% typical powerloss from engine to rear wheels.
If you made 157 rwhp then you picked up approx 12 to 17 hp; ECM tuning would probably pull out a bit more at all rpms, not just at the peaks. And so would a good cold air intake -- having a flow-restrictive filter really isn't a problem with a near stock LO3, but pulling heated underhood air isn't helping IMO.
Old Apr 2, 2007 | 09:19 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Re: dyno numbers
Yea if i was to keep the stock TBI F.I then i'd have it tuned. my A/f ratio was flatlined at 11:1 throughout the RPM band. and at idle was around 13.5:1, yea she's alittle rich...lol but pretty soon i'm switching to Carbed with all new parts as per my sig. then once i get it together i can tune the carb for best performance on my schools chassis dyno
Old Apr 3, 2007 | 07:05 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: dyno numbers
I'm sure you've found that there are quite a few of us tuning the factory TBI ECM. With about $150 worth of tuning equipment and a laptop you can have complete control over your engine. It'll actually be cheaper than getting a return style regulator, carb, non-CC distributor and swaping it all over.
It won't be as simple to tune as a carb, but you'll learn more about engines and what it actually takes to make one run well. Your stock TB will support just over 300hp and a BB unit will support over 425hp.
Old Apr 3, 2007 | 02:55 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Re: dyno numbers
Dyno numbers and setup are in sig.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
