Code 44 questions
Old Aug 28, 2001 | 05:19 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Code 44 questions
Hey guys I have a question. I keep getting a code 44 (02 sensor lean), I get it when the car idles for a few minutes when warm. When I get on the gas and pull away it goes away. I did a scan and the car is running rich across the entire rpm range.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Aug 30, 2001 | 12:22 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
You might want to check to see if the 02 sensor cable burned through and is grounding out. It happened to me when I had my car in Germany. If that doesn't fix it, replace the 02 sensor.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
