Just how big can I go?
Subscribe
Sep 14, 2001 | 11:00 AM
I am looking at a 383 running a bigger cam. I don't have the final specs right now but around a .490 lift and 10.1 compression. Now I know that the Pro-jection system can handle this but can a GM set up do this. By GM I mean will a 454 TB with GM injectors and a custom prom push this motor? I am working with a local engine builder and he was wondering what the limits of GM TBI's are. If you guys need more detailed specs let me know. Thanks!
Reply 0
Sep 14, 2001 | 11:19 AM
it could, though should ya? hmmm, i wouldnt with that much motor, depending on what you want it for. all out racing? driving and racing? if its a driver, im sure you wouldnt mind sacrificing a few horse for more drivability.
and you are one more case that proves i need
to build my 2.25" 2bbl unit.
december is the month for having the prototype made now, its been nearly a year since i first started working on it.
Reply 0
Sep 14, 2001 | 11:33 AM
The Stock GM 454 TBI unit is about 640 cfm. Run the numbers and see what you come up with. You can do a little porting and poliishing on them and up that number the about 650. You would definately need bigger injectors and a custom prom. I think .490 is really mild for a 383. With a cam that small in a 383 I think a GM tbi will handle it just fine. but that just my opinion.
-Lars
Reply 0
Subscribe
