Quick question about this project im doing on my 92' camaro
Old Oct 5, 2001 | 11:34 AM
vortech305's Avatar
I bought this t-5 from a guy which was on a 88' 305 TBI motor, THe lettereing on the tranny is their but all it says is 88 and Borg Warner Automotives, and some numbers, Did Chevrolet give World Class T-5 on TBI motors?? or where they only on TPI's.
Old Oct 5, 2001 | 12:24 PM
Tas's Avatar
Tas
there was an older and a newer T-5 for thirdgens. I don't remember which one was which and what the transition year was. Check the FAQ. The gear ratios on the later TPIs were better than the TBI t-5. It should be the same brand though. I think just 4th or 5th gear is different.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 5, 2001 | 01:36 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You can tell the difference between the WC-T5 and non-WC easily (if it is out of the car). The non-WC has a round plain cover just above the output shaft. It also has a short plastic breather where the tailshaft casting mates to the body of the tranny. A WC-T5 has a machined cover that is stamped with some numbers and lettering and a plastic fitting connected to a roughly 12" long black plastic tube for a breather. Your 88 should have a World Class tranny. Unless someone swapped it (like on my 88 Iroc). The RS T5 has a better first gear ratio to help launch you off the line, to compensate for the 3.08 ratio rear end.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 5, 2001 | 01:49 PM
vortech305's Avatar
well it says 88 on it, and from the points u guys made i still cant figure out if its a WC or not, As i took it apart to clean it up and paint it i notice the fork 2 metal pieces which hold the pivot point thing is messed up at least one is cracked and broken, So im guessing i gotta buy a new Fork, How much do they go for from GM, Finding a Fork for a t-5 in the junkyard is a joke, What about Lakewoods Fork from Summit or Jeggs are they any good. The stock fork on the 88' T-5 says on it
V8 14075725, any help?
Old Oct 6, 2001 | 06:35 AM
DM91RS's Avatar
Car: 91 RS
The trans should have a metal tag on a housing bolt with the i.d. number on it. The i.d.# for the trans you are refering to is 1352-176 2.95 1st gear .63 5th. One way to tell for sure if it's world class or not is to look at the front countershaft bearing from the outside and if it has a Timken name on it. If it's not world class it will say Torrington. Good luck.
91 RS 5.0 TBI....Edel. TES headers .. 3" exhaust ...Dynomax muffler...5spd... 3.08...underdrive pulleys...cold air K&N flat bottom breather...strut tower brace...6-point rollbar...sub-frame connectors...Koni shocks and struts...16" Black GTA wheels...Autometer guages...custom chip...Grant steering wheel...a/c delete...smog delete...rear seat delete...ultimate TBI mods...afpr...36mm front and 25mm rear swaybars with poly bushings...
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
