air fuel ratio gauge question
Subscribe
Oct 17, 2001 | 04:42 PM
im thinking of getting an air fuel ratio gauge and i was jsut wonderin how you go about hooking it up?do you just have to splice into the o2 sensor?or is there more involved.thanks.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims,Z28 bowtie grille insert with driving lights
-L03 305,TH700R4,2.73's,only mods for now are...Flowmaster 80 series replacement muffler,accel wires and coil,14x3 open element with K&N,lockup switch at the track,and a catco cat.
-best 1/4 mile times to date:15.89@86 with a 2.26 60 ft
Reply 0
Oct 17, 2001 | 07:18 PM
Yup, just splice into the o2 wire at the ECM, tap into some power for the guage from the guages fuse, and locate a ground.. and thats it. Then try and watch the road.. I found it amusing to watch when I first installed it.
Okanagan Thirdgen Association
_ _____________________ _
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Reply 0
Oct 17, 2001 | 07:35 PM
Just be sure to tap into the correct wire ("signal" wire) on a 3-wire O2 sensor!!! You'll blow the meter if you connect the O2 meter signal wire to the O2 sensors 12 volt heater supply wire. Wiring with a single-wire O2 sensor is a little simpler
And, solder the connections or create the best other connection you can... Cannot have any deterioration in the signal or possible short or ground out or you could be in trouble, never mind having to drive home in "limp-home" mode.
[This message has been edited by fast_broker (edited October 18, 2001).]
Reply 0
Subscribe
