Belt Question
Old Apr 29, 2007 | 06:29 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Belt Question
I was just wondering what size belt i would need if i bypass my AC and Smog Pump pulley? Thanks
Old Apr 29, 2007 | 09:10 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: Belt Question
as far as i know you can't bypass your ac,because you need to have the belt go around a pulley on that side to use the tensioner and to be able to wrap it back around the water pump. but you can bypass your smog pump, i did and i used a 99" serpentine belt.
Old Apr 29, 2007 | 09:19 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Re: Belt Question
They do make A/C and Smog Delete Pulleys. I don't remember the part numbers but I'm sure a quick search would turn them up.
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: Belt Question
Yeah, I think you'd have to remove the A/C and put an idler pulley there so it's routed right and keeps things spinning right, but the AIR pump can be bypassed.. I'm not 100% sure as my car doesn't have a serpentine belt, but I think that's what you have to do.
Old Apr 29, 2007 | 10:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Belt Question
Do a search for A/C delete pully. The smog pump can just be removed with the right belt. Searching for smog pump removal or similar will bring that up. Its also covered in the tech articles.
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
