YOU GUYS HAVE TO HELP ME, AT LEAST LOOK AT MY QUESTION
Old Oct 26, 2001 | 08:16 PM
90rsMustangkiller's Avatar
i have been trying to start my 90 rs, and their isnt any fuel comming out of my new injectors. The fuel pressure is fine, but the gaskets that go from the fuel line to the tbi need to be replaced. tommorow im going to get the new gaskets, and put my old computer back in, to see if thats the problem. has anyone here ever had the same problem. i wanna get this thing running
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension. MSD probillet distributer/ coil,
Old Oct 27, 2001 | 01:29 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Is the fuel pump priming? What ECM swap did you do?
Old Oct 27, 2001 | 01:30 AM
91 Bandit II's Avatar
take a test light to the injector harness and make sure your getting a signal there.. while you turn it over
Old Oct 27, 2001 | 10:11 PM
Faithbird88's Avatar
did your car just suddenly die on you, or did your car not start when you replaced the injectors, if it just died on you, your pick up coil, and ingnition module is most likely bad, i had this same problem thinking it was my ECM or injectors, i had to replace my ingition module and pick up coil in the distributor, the pick up coil service required me to remove my distributor completely but if you have a basic Mechanical experince its very easy, and these parts together were a total of $30.00, this should slove your problem
any other question e-mail me at Londonaftermid21@aol.com
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
