i want to do this to my 91 bird this winter, i would like simply take out my 305, and swap a 350 under my tbi set-up, of course add a more powerful cam and headers, etc. but what would need to be done to the comp, and injectors to do this swap? I want to use my tbi set-up, and not just throw a 4 barrel on it. im sure some of you guys had done this swap before, ive always gotten good advise from people on this board so thanx in advance for any help
"If its in my way-It gets run over"
--'91 firebird
305 TBI
Hypertech chip-thermomaster
Edelbrock performer intake
Crane compucam 2031
B&M shift kit
straight pipe exhaust-with Flowtech resonator tips
160 thermostat
open element
--'91 firebird
305 TBI
Crane compucam 2031
B&M shift kit
160 thermostat
open element
Minimum parts required for 305 to 350 TBI Swap are:
350 Truck Injectors(2) GM Part#17112493
350 Truck Knock Sensor GM Part#10456288
350 Truck Knock Module GM Part#16128261
Got mine as a package deal from Ken Casey at Burt Chevrolet(parts dept.) in Colorado.(303)761-1286
I have a 300HP crate motor,Crane Compucam,Edelbrock TBI Intake,Ported Turbo City Throttle Body & Adjustable Pressure Regulator,Open Element,SLP 1-5/8" Headers,3" Cat,3" Flowmaster Cat-Back,T5 trans(soon to be replaced with Tremec TKO),3.73 Posi Disc Rear and Custom Fastchip Prom.
Hope this Helps,
-Rich-
Hope this Helps,
-Rich-
thanx man, any infoon the comp and chips though? possibly go with the truck ecm? or maybe another that will plug into my stock harness
--Stormr
--'91 firebird
305 TBI
Crane compucam 2031
B&M shift kit
160 thermostat
open element
--Stormr
--'91 firebird
305 TBI
Crane compucam 2031
B&M shift kit
160 thermostat
open element
Custom Chip is best,but you may not need it,depends mostly on cam.Should be able to use same computer with either custom chip or I keep hearing about a stock Caprice chip that'll work,but I don't really have any details on that.Anybody?
Some say the stock chip in the computer you have will work with some fuel pressure increase.
-Rich-
-Rich-
