tbi flooding after new fuel pump
Old May 12, 2007 | 05:32 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
I've got a tbi 350 and I just replaced the stock 305 fuel pump with a stock tpi pump and now my car is flooding. The only things I can think of are maybe my fpr(stock 305) is out, or maybe theres some sensor screwed up. My temp gauge quit working and I replaced it with a mechanical one coming from the manifold...don't know if that will affect anything but I don't know much about this. I was thinking maybe my car is trying to warm up or somthing, but I have no clue.
Old May 12, 2007 | 07:41 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Re: tbi flooding after new fuel pump
I would think you would have to turn the pressure down on your reg now...I know the TPI pumps put out more pressure.....
Old May 12, 2007 | 08:06 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id check the fuel pressure first to rule it out. If it looks ok, then it could be an unplugged or faulty CTS. The other possibility is leaks at the pod or injectors.
If the pressure is too high, then it could be that you reversed the return and CC lines. You can check this by disconnecting blowing air through the metal return line next to the charcoal canister (by mouth using a vacuum hose will work). There should be some resistance. If air passes freely through the CC line, then theyre reversed.
If this is ok and the pressure is still too high, then your SOL unfortunatly. The only way around it is to run more pressure and adjust the BPC in the prom.
Old May 18, 2007 | 09:07 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
any updates?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
