tom400
Old Nov 22, 2001 | 05:26 PM
allious's Avatar
tom400
tom,
i am from the crossfire forum and had a question. i have an oppotunity to buy a small block 400 to go with my 84 vette and was just curious with what modifications you had to do to make it run right in your t/a.
i was in the process of building a 350 with L98 aluminum heads, but i think i may be better off with the 400, what do you think?
Old Nov 25, 2001 | 10:56 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Hey whats up!
I can't get on the forum right now, b/c I can't from work, and my computer at home is screwed up.
Anyway, to make the 400 run pretty d@mn good, I HAD to port my intake to the max, install 75 lb/hr injectors (from a 454) and the vacuum referenced fuel presure regulator. I bored the TB's but I don't think that was necessary. The big engine needs more air and fuel. Thant's all.
I would do it agian over a 350. I have NO MONEY in the combo, and I can out run stock LS-1's in the 1/4 all day long.
Old Nov 25, 2001 | 09:56 PM
allious's Avatar
thanks,
we miss you over on the forum. do the 454 injectors fit without any modifications?
Old Nov 26, 2001 | 11:10 AM
Engine: LT1, L400
Thanks for the compliment
Yes the 454 injectors slide right in. They look exactly like the one you have right now. Easy.
