What 02 sensor should I get?
Old Dec 11, 2001 | 10:24 PM
Nate Hanson's Avatar
I'm gonna be running new true dual exhaust on my TBI 350 S10, and I wanna know if I would benefit from a heated o2 sensor? How would I go about installing something like that.
nate
1991 Chevrolet S10, 350 TBI/ TH350
Old Dec 12, 2001 | 12:20 AM
JPrevost's Avatar
Car: 91 Red Sled
Heated o2 sensor isn't any better unless you burn your own eproms to go into closed loop faster! A good o2 sensor from any parts store is fine. They're all at the same point in technology and you're not talking about a wideband o2 sensor so just get one from the local car parts or pep boys like me .
There isn't really a bad o2 sensor. If you want to go heated you can do a search and you'll get lots of info which I don't have infront of me right now. The heated o2 sensors come in 3 and 4 wire design, they're exactly the same but one of the wires on the 4 wire side is a sensor ground but if you are screwing the sensor in the y-pipe then it's already using it's body as a ground (in the 3 wire version). The other 2 wires are for another ground and positive ignition hookup for the heater element. Like I said before, don't waste money on a heated sensor if you don't change the go into closed loop faster. Even then it isn't always a good idea because the until the coolant temp reaches a certain temp the exhaust gas temp....well don't make me go on a tangent, just don't waste money on it .
Old Dec 12, 2001 | 01:15 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
My van originally had a heated O2 sensor in the Y-pipe and it made the ECM go ape$hit if you let it idle too long at start up. With the non-heated O2 sensor, my ECM never goes into closed loop unless I drive it. With the heated O2, I *think* it was trying to go into closed loop and the ECM didn't like that at all. It's prolly a matter of having some PROM parameters set right, but it runs almost perfect now, so I'm not gonna bother it.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
