Fuel Pump?
Old Jun 22, 2007 | 09:59 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Fuel Pump?
I've had a 350 with 305 Everything hooked to it, Now Everything is 350, besides the Fuel Pump. When Going up a Hill or something if your going 30 and hit it to WOT it pulls for a split second and then theres Nothing.. the tachometer reads 5500 rpm for a second and then it up shifts and it pulls a bit. However at lower RPM's it Pulls pretty Good..
So, Is my 305 Fuel Pump maxed out?
Old Jun 23, 2007 | 10:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuel Pump?
I will assume that you are running a 350 TBI with the 305 injectors and tune? If so your problem is not fuel related (well it is one of your problems) but more so you are running the stock chip with your new set-up. The stock calibration for the LO3 is blind to any changes you make (ie 350 set-up) and will run like death until a new chip is burnt (assuming fuel modifications are also made.).
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
