HELP!!!!!!!! NOW please
Old Jun 28, 2007 | 07:29 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
i was just working on my car on the throttel body and i broke the part where the fuel lines go into the back of the throttel body i was woundering if this would work part number 510-534-162 from jegs please help me need help fast ??? just type that number into the search and it will bring it up. HELP
Old Jun 28, 2007 | 08:26 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Engine: 305 Mod/Tune TBI
Axle/Gears: 3.63
Re: HELP!!!!!!!! NOW please
the only things i would fear, after reading about this is the bore size of the barrel. all replacements i have found (for the most part) have been 2" barrels, while the stock TBI has a little less then that. 510-502-6 may work.
Old Jun 28, 2007 | 09:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Just get another pod off of ebay or something. Those fittings should be snug, NEVER tight, or itll force the threaded portion away from the rest of the pod. I would say that anything over 10-15 ft-lbs is too much torque.
Also, that pod is for the small Delphi inectors. It wont work in the stock application, and kinda sucks to boot. I have the holley unit, and like lots of other stuff from them, the quality is in the pooper. It required lots of work to make it right.
Last edited by dimented24x7; Jun 28, 2007 at 09:12 PM. Reason: Automerged Doublepost
Old Jun 28, 2007 | 09:40 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
ebay may be cheaper, but you should be able to find a good TBI unit at a wrecking yard close to you.
i could be wrong, but as far as i know, the TBI is the same as what they put on the pickups. just get one from the same size motor as what you have.
