TBI idle issues
Old Sep 22, 2007 | 11:18 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
TBI idle issues
with this nice cooler weather lately my TBI has been idling very high when starting and it stay in that mode for prolonged times and acts like a carb ( you can mash the pedal and it drops down to normal) but then when you press the pedal again right back into fast idle .... This fast idle can get up to say 1600rpm and it will take a few miles before it decides to drop down and stay down ..... By cooler I dont mean 30 degree days maybe 70's but when it's like in the 80's and 90's the car doesn't do this.Or is this just normal, just kinda though a few miles at this elevated rpm was a little weird for an injected car no matter what.
Old Sep 22, 2007 | 11:52 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TBI idle issues
1167
I would check the usual suspects:
Binding throttle shaft - cable.
IAC - clean it and reset it.
CTS and IAC
//RF
Old Sep 22, 2007 | 11:58 AM
Jproz1167's Avatar
Re: TBI idle issues
nothing is binding that I am sure of .... and no codes are being set
just wondering if it could be the IAT sensor wigging out maybe and not throwing a code
Old Sep 22, 2007 | 02:54 PM
MorrisL03's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
Re: TBI idle issues
Ive had this same problem recently in cooler weather. I have a 175 thermo in it right now. When I stop at a light it will idle about 1100 then take about 10-15 seconds to settle down to about 600-50. Im thinkin IAC.
Old Sep 23, 2007 | 01:32 AM
Jproz1167's Avatar
Re: TBI idle issues
well added a 195 thermostat and got my heat stove working right it had a faulty thermo switch and replaced my CTS car runs nice now doesn't do that high idle thing anymore. I think it was the lack of hot air more then anything in the air cleaner causing it.
Old Sep 23, 2007 | 07:54 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: TBI idle issues
No, it was the cooler thermostat. There is a table in the chip that designates the desired idle rpm vs. temp. At the cooler temp your chip was just asking for a higher idle.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
