IAT question
Old Oct 21, 2007 | 12:57 PM
cliffhanger2486's Avatar
Car: 88' Firebird
Engine: 5.0 TBI
HELP with IAT
I put in a new open air element for my 88' TBI, but I wasn't sure where to put the IAT plug, as there is no place to put it like there was in the stock air cleaner. Needless to say, I melted the top plastic part of it. Do I need a new one, and is it necessary to get one before I drive the car again? Where should I put it if i get a new one? (that is if I need a new one)
Old Oct 21, 2007 | 07:02 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: HELP with IAT
I'm pretty sure you need it so go ahead and replace it.
After you do that, tuck it away somewhere close to a cold air source so it can read a cool measure making your A/F mixture what it should be for max performance. BE CAREFUL THOUGH: If you ground it out against some metal it could zap your whole electrical system.
Old Oct 21, 2007 | 08:26 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: HELP with IAT
How the hell did you melt it ? Anyway, just unplugg it for now and the car should still run. But you will want to get a new one ASAP and you will throw a code while you drive around without.
Old Oct 21, 2007 | 10:22 PM
Car: 88' Firebird
Engine: 5.0 TBI
Re: HELP with IAT
alright thanks. I'll take your word for it.
Old Oct 22, 2007 | 02:56 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: IAT question
dont just throw it up anywhere put it back in the air cleaner. take the base off like i did and just drill a hole big enough and pop that sucker right back in there and itll be fine. the base should have circular marking on the bottom as to where to cut.
Old Oct 23, 2007 | 03:13 PM
Ronny's Avatar
Re: IAT question
mine is hanging from base of AC with a tie wrap. just dangling there for now.
Old Oct 23, 2007 | 03:36 PM
Car: 88' Firebird
Engine: 5.0 TBI
Re: IAT question
sounds like a good idea, thanks. I might just drill a hole in the bottom of the new air cleaner like there was on the stock one.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
