3 degrees before top dead center...(HELP on the timing)
Old Nov 21, 2007 | 01:39 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
hi guys.......
last year when my motor was swapped in, the crate motor builders in Arizona recommended that I set my timing to 3 degrees before top dead center TDC.
i still have my 5.0 injectors on my 350cid. I never got around to chips and injectors (hardly home anymore). The car runs sluggish and rich. VERY RICH...Most of the time I smell the richness everytime i shift gears.
My idle is Great! But how can i keep my idle settings and turn up the timing to lean out ****SOME**** of that excess fuel. Im averaging 185 to 200 miles per tank and Sorry a$$ power too! My 5th gear has no *****.
i do have the 5.0 injectors so i dont want to get to carried away and get SUPER lean.
i am aware that i need 5.7 chips and injectors. but i need a quicker fix. Sorta like a bandaid on this matter.
ANYBODY?
Old Nov 21, 2007 | 11:29 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Re: 3 degrees before top dead center...(HELP on the timing)
You've got the wrong idea. Changing your timing will not affect fuel trim. You don't set the timing rich or lean, it's advanced or retarded. You need tuning. You're running a 350 on 305 injectors...what does the ECM think it's running? You MUST start there.
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
