is it my fuel pump?
Old Dec 26, 2007 | 08:22 PM
4banger82's Avatar
Car: 84 camaro F41
is it my fuel pump?
hey guys,
i got a v-6 tbi that just stopped running in a parking lot. ie i was driving into a spot, half way in, my car died. i tried to restart it there numerous times with no prevail. got wd40 and sprayed it in and it would start for a second, so i assume that my fuel pump cr@pped out on me and needs replacing? any other thought or ideas on what it might be or what i should do?
thanks,
ike
Old Dec 26, 2007 | 08:25 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: is it my fuel pump?
check the fuel pump fuse and replace the fuel filter first... maybe that's it!
Old Dec 26, 2007 | 10:25 PM
4banger82's Avatar
Car: 84 camaro F41
just replace the filter. the last one was shot but still wont start with the new. when i took it off i turned on the car and there was a bit less fuel than should have been comming out. this mean i gotta do the pump itself? thanks for the reply.
Old Dec 27, 2007 | 10:03 AM
Jason89RS's Avatar
Do you hear the pump prime when you turn the key to the on position?
Old Dec 27, 2007 | 01:58 PM
4banger82's Avatar
Car: 84 camaro F41
i only started hearing it after i replaced the filter.
Old Jan 26, 2008 | 02:57 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
ignition control module ?
Old Jan 27, 2008 | 01:41 AM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
when my fuel pump died i had just pulled in with no issues, turned off the car and filled up the fuel tank(apparently this is a common occurance with dying fuel pumps). check your fuel pump fuse for fun, it could be it but I doubt it. it could also be your fuel pump, but check a few other things out first:
there are ways of checking the voltage on the coil, which could also be it. I don't know those ways. if you know someone who does, have them check it.
there's also potential that the battery is low. i've been through times where the battery was too low to start the car but high enough to run several lights in the car. so checking your battery and alternator wouldn't be a bad idea.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
