strange 4 bbl tbi unit i found
Old Dec 28, 2007 | 04:59 AM
brandont454's Avatar
Car: 95 ecsb c1500
Engine: 350 tbi
Transmission: 4l60e w/ 2500 stall
Axle/Gears: 8.5/3.42
scanning ebay i came across this
http://cgi.ebay.com/ebaymotors/BIG-B...em180198712821
is anyone here familiar with it?
Old Dec 28, 2007 | 06:34 AM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Re: strange 4 bbl tbi unit i found
not familiar, but a perfect component to use with RBob's ebl. better than trying to build a dual 4bbl manifold with adapters. just think the ability to use 4 90 pounders. would look real good on a 632 i found.
Old Dec 28, 2007 | 07:14 AM
Car: 95 ecsb c1500
Engine: 350 tbi
lets be honest here, the only aesthetically proper way to fuel a 632 with tbi would be a custom sheetmetal intake that has individual runners with 8 bored out 53mm single tbi's from a crossfire intake.
Old Dec 28, 2007 | 09:04 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Looks homemade, those are GM injector pods and holley's 4-barrell setup had the "tower" coming out of the middle of the base plate. Those are huge throttle plates as well, looks to over 2".
Old Dec 28, 2007 | 12:53 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
I tend to agree - it looks like a Holley square base from a carb, with oval adapter plate to mount two injector pods back to back. Note, no IAC to be found. This thing should be fun to make it idle. Also, how about TPS? TPS can be driven separately of the throttle lever via adapter cable.
//RF
Old Dec 28, 2007 | 02:39 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
That has to be custom. It looks like a standard base with a custom made top plate... I'm thinking horrible air flow because of the dual pod towers... still quite unique though...
92camaroJoe
Jul 29, 2023 07:57 PM
red90IROCls1
Aug 25, 2015 06:56 AM
92camaroJoe
Aug 13, 2015 06:07 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
